Build 1997 FZJ80 to HDJ80 1HD-FTE + H152F
Cheers
@SNLC Beaudesert exhaust?
12mm fuel line all bent up, using stock mounts and it’s in the stock location.
Used the 1FZFE supply for our return line.
Now we just got to modify the pickup in the tank for 12mm.
Cheers
Nice job, why can't you use the ft pickup, thought you had the ft truck for spare parts.
We are using an FZJ80 fuel tank. We are modifying the pickup to be 12mm.
I don’t think the HDJ pickup is 12mm either. So if we were using a HDJ tank it would still need to be modified. The donor Cruiser is in poor condition, I doubt the tank looks cery good inside. The FZJ tank we are using is super nice inside.
Cheers
We ended up using very little parts from the HDJ80. Not a fan of used parts when new is available or easily fabbed and/or improved. The donor did its job. I was able to use the shifter console to scan and print the new one with a few modifications.
Boomer alert.
How does the factual comment that May temps in Idaho are about the same as winter temps in Florida have anything to do with boomers?
