the "mudding" and pressure washing could certainly be the culprits for an electrical issue. i would definetly unplug each transmission related component, clean it up, in spect, apply some dieletric grease and put them back together. make sure you check the speed sensor as well. most people neglect to do so.
however, the physical symptoms you're experiencing seem to be fairly consistant and can just about be duplicated given the proper circumstnaces. and the issue only happens under those conditions. is that correct?
if so, then you're mostlikely dealing with a mechanical malfunction, not an electrical problem.
given the milage on the transmission, that's not really out of the picture. i think it may be a wise idea for you to take this cruiser to a good transmission shop. tell them about all the "research" you've done and let them try to diagnose it. a lot of independant shops will do it for nothing or next to nothing. the diagnostic test should include scanning the computer for any codes ( both instnat and memory ) as well as a driveability test. don't go to aamco, they'll just end up milking you for all you're worth.
i spent 12 years of my professional life in the transmission industrie...............
georg @ valley hybrids
