The troubleshooting pages of the transmission section has you count the flashing "OD OFF" light. Problem is, mine does not work. When I turn the OD off, no light. Tried pulling codes, no light.
Is there an alternative to this method, or a way to fix the OD OFF light?
Could you hook up a test light to the respective wire and count it that way?
But then again, if I change the "D" light bulb, will I be removed from the club? Not sure if I want to do that.
