The male splices are 82998-12080 and the female splices are 82998-12090. Both are still available.
Excellent!
Dan, you only saw half the story.
If I ran with the big dogs, I'd have to charge as much as them.![]()
Other interesting notes on behavior for other who may come across this:
As long as I start in "L", I'm fine. After I start moving and shift into "2" or "D" the transmission behaves normally. The same even goes for reverse if I reverse fast enough.
I replace the damaged wires in the plug going to the transmission and still have the same trouble with the shifting. The transmission doesn't want to start out in 1st gear, only when you shift it manually to low will it go to first....
Another thing I've noticed is the O/D light will go to blinking.
