For Sale 1991 HDJ81 Toyota Landcruiser
Victoria,BC
Year
1991
  1. 80 Series
Mileage
239369
Color
rgb(97, 95, 95)
We've had this truck for many years but reluctantly, must let her go.
239,396km Almost 0 off road... Near Flawless vehicle.
Recently, the head was professionally rebuilt and machined, new pistons, all motor seals, timing belt, tensioner, water pump all brand new.
I have virtually every receipt for every part I have ever spent on this truck. You will not find another truck with as comprehensive documented service history.
The beb's were don't when I first got it at 71k and have been done again (100k PM) at 170 and again at 200k
Brand new front axels & diff bearings
Custom bent 3" stainless mandrel exhaust from the turbo back.
Big brake upgrade with 100 series pads, new.
Factory fuel filter tossed in the garbage in favor of a racor 2 micron setup. All new filters with rebuild.
Fuel system, including injector pump is completely new and rebuilt 2022 ($7,000)
Timing belt and tensioner are done. And again with rebuild.
Brand New rad and heater core.
Bypass coolant filter.
Full gauge package. Pyro and boost on the pillar and trans, oil pressure, coolant temp , batt voltage with hour meter on the console.
Top of the line trailer brake controller and proper trailer light circuit.
New shocks front and back.
New tire rod ends all around.
Birfs Completely rebuilt in 2022.
Brand new BF Goodrich 35" Tires 2022 All terrain & spare.
Lx450 wheels with Toyota Center caps all are wrapped in toyo open country AT's 265/75/16's.
3rd row seats professionally installed, so it seats 7 legally !! ($5,000)
Huge trans cooler.
Fan hub serviced with Toyota silicone oil.
Crank case vent re-routed to catch can.
Power steering pump completely rebuilt with new resivior and pressure line.
HIR bulbs for low beam and HID 35W 4300k high beams.
Stereo Upgrades.
Alarm, remote start anti theft system with 2 way remotes.
Stock alternator has been changed out with a 120 amp Denso unit.
All new power window switches and new front window regs/ with motors.
Factory winch.
Factory lockers.
Pin 7 mod.
Console fridge/freezer.
Turbo timer/Boost controller.
All LED interior lighting.
Husky liners for second and 3rd row.
New wheel bearings when I re -sealed the front axel last ( probably about 50 k ago.
Best deal you will ever find on a truck like this considering it's seen 1%
off road.
Underbody is almost flawless, including the heater lines...
The vehicle runs like a top but will require a replaced head gasket. We've JUST noticed a leak and don't have the time or funds to pursue the fix, the reasoning for this sale.
contact:
Ed, email:
margobiggs32@hotmail.com
for more info
$23.500 CDN OBO
