- Thread starter
- #2,581
Now see that's where you are wrong ..... The HJ75 is slow enough that I have to be concerned with being overtaken by bugs from the rear. Some of those little suckers can fly fast. : )Um,
Those go on the hood, not the back.
Does your European DD have this issue?
Is anyone getting this message when they try to post or is it simply an issue with my IPad?View attachment 923403
in fact it just happened when I posted this response......
Last time I got that error, when I came back to the thread, I had multi-posted about 10 times. Took a lot of post deletions to fix it.
Do you have brake fluid in the slave cylinder? Clean?
Hmmmm .... thrust reversers
I do not know if it has one, but if there is a check valve in the vacuum line, is it OK?
Yes sir ......go buy a vacuum tester and get R done.
