- Thread starter
- #2,601
South America is finally represented in the Cruiser garage. ( courtesy of a recently delivered HJ47 )
Charles -
...............concerned that you had taken delivery on a HJ47......
Been there ..... Done that.
I enjoyed my 40 Series but probably won't go back in that direction again.
STUPID BRAKES .....
Despite replacing the brake booster, which was faulty, the original issue ( no pedal travel and so so brakes ) is unfortunately back. The next step will be to replace the brake master cylinder with a larger BMC from a FJCruiser and install a brake compensator which hopefully will correct the issue.
Are you sure you have enough vacuum? Lack of vacuum would make the pedal hard to push, and little travel. My brakes work fine, but the clutch runs out of vacuum when holding the brake. Pull and plug the vac line, and see if you feel a change.
Replacing the brake master cylinder is not a done deal, but simply an option. A friend put a FJCruiser BMC and compensatorHold on Charles! If you go to a larger diameter master, you'll get less travel, not more, unless you grow the brake lines too.
All of the stock parts in good order will give a nice pedal feel. Are all your wheel bearings tight and the rear brakes all working properly and well adjusted? They are normally the source of such issues.
might have been his privileged son, but the Olivia with John on the end, well...
