Build 1983 Cruiser Story
No updates for almost a year! I'll try and catch us up. '
Replaced the old stretched out handbrake cable with an OEM replacement and found this old Pickup, Van & 4WD Magazine from 1981:
Still serving Daily Driver duty!
New front seatbelts from seatbelt planet!
Up to 131,000 miles on the odometer and climbing!
Onto the latest.
Over the weekend, I took the Cruiser on a 2 hour drive over to my wife's cousin's cabin in Sadieville. we had a raucous poker party Friday night and our wives brought our families the next day. I took my brother-in-laws with me in the 60 for the poker party, neither of which are "car people".
One of them made the comment that it seemed like I was moving the steering wheel 45* before anything would happen. So of course, I started paying attention and noticing it too. Driving it every day for the past ~6 years, I guess I've just gotten used to the gradual increase in steering play.
So yesterday, I greased all of the steering joints, tightened the relay rod end and made a small adjustment on the steering box adjustment screw and BAM! What a difference, the truck drives like it's 1983 again! I love quick easy fixes with massive improvement!
Next I need to address a hard start issue, when sitting overnight, even on warm summer mornings choke is required to get it started. After that its fine the rest of the day.
Here are some photos from the weekend.
Which one did you buy from them? Hey thanks
It's been while!
I was keeping up with a lot of you on Instagram but about a year ago I deleted that because (with the exception of LC related content), it was such a time suck. So hello again to those of you that still peruse both, I'm not MIA!
The stock clutch made it 42 years and 143,000 miles and I replaced it this summer. I got the clutch kit from Kurt @cruiseroutfit and some miscellaneous parts from various other sources including eBay. It's done but a clutch in this truck with the transfer case still attached is a big, dirty job.
I purchased the Harbor Freight Low-Lift 450LB transmission jack and that helped quite a bit. The other, biggest helper (which I saw on MUD [I think @OSS] ) was cutting the heads of long bolts and installing them in the transmission (to bell housing) bolt holes for alignment.
The flywheel was smoked so I had a local machine shop (HAAS Machine) performed the step grind without issue, I also had Inge Dry Ice Cleaning dry ice blast all the crud off the transmission while it was out!
Its all back together and still pulling DD duties!
