SOLD 1979 TOYOTA LAND CRUISER FJ40 Power Steering /Air Conditioning US Specs (225 pictures)
Status
Not open for further replies.
Newnan, GA
Website
www.cwcruisers.com
Year
1979
  1. 40 Series
Mileage
117093
Color
White
Outside Link
https://chriswade.smugmug.com/1979
USA Version
** Body Condition **
This Land Cruiser lived most of its life in South Carolina before I purchased it. Due to the exceptional care by the previous owner, rust was not a factor with this vehicle. It was repainted piece by piece using factor White (color code #031) in base coat clear coat. No expense was spared with the paint work on this Land Cruiser. West Side Rods and Customs in Thomson, Georgia performed the work. The paint process consists of:
2 coats of polyester primer to seal the bare metal then any bodywork on top of it. Follow that with 3 coats of polyester primer. It is then block sanded with 120 grit, 180 grit, then reprised with urethane primer. Finish sanded with 320 and 600 grit. 3 coats of base and 4 coats of clear are applied, color sanded, buffed and polished.
The hardtop had never been removed before painting. ** ALL STEEL ** No fiberglass, aluminum, rhino liner, or diamond plate on this beauty. New Toyota OEM parts include: front & rear door weatherstripping, roof weatherstripping, front & rear turn signal assemblies, mirrors, windshield, door hinge pins, 4wd & Toyota emblems, kick vent gaskets, license plate frame.
** Interior Condition **
All seat upholstery (new foam on front seats), headliner, and sun visors have been recovered. Front seat frames & roll bar have been powder coated. Dash is original with no cuts or tears. Original Toyota mat with Lloyd custom mats over top. Under mats is custom sound deadener (not glued in). All dash controls, gauges, and lights in working order. Rare factory AIR CONDITIONING. Jump seats and new seat belts in place. OEM tool kit, spare tire jack, and rods in original mountings. Sony AM / FM added for superior sound.
** Mechanical Condition **
117,093 miles on stock Toyota six cylinder (2F 4.2 liter). 4-speed synchronized transmission 4-wheel drive, factory emission equipment intact. Rare factory POWER STEERING. 5 NEW OEM wheels powder coated on BF Goodrich 33x10.50x15 tires. Sky Jacker L40FS 4 inch Suspension Lift System with Hydro Shocks, greasable shackles, fuel pump, alternator, battery, wires, NGK spark plugs, distributor cap, rotor.
Engine compression reads: 1-135psi, 2-130psi, 3-127psi, 4-135psi, 5-130, 6-133psi
Vehicle ID: FJ40301114
Clear Georgia title and registration in my name
AS DESCRIBED THIS FJ40 IS STUNNING AND TURNS HEADS WHEREVER IT GOES. THIS MODEL IS RARE AND COMES WITH SOUGHT AFTER 3.70 DIFFERENTIALS, FATORY 22 GALLON FUEL TANK, (OPTIONAL) FACTORY AIR CONDITIONING & POWER STEERING.
HARD TO FIND IN THIS ORIGINAL RUST-FREE CONDITION. LOCATED JUST OUTSIDE OF ATLANTA,GEORGIA. show contact info
$59,000.00
For 225 detailed pictures before, during, and after restoration go to this site: 1979 White South Carolina - Chris Wade - https://chriswade.smugmug.com/1979
Status
