Gary, thanks for posting the pictures of this build, awesome work...makes me wish sometimes I was back in the States for the availability of things to work with....seems we have similar ideas but vastly different execution....again thanks..Lee
You are welcome and thanks for that comment.
Gary
Sweet build man, which model Hurricane AC system did you go with and how do you like it? Looking for AC for my FJ55
Tucker
I used the Hurricane 3000 inside system, and ran the duct work behind the dash to put air our two side vents and two in the middle of the dash.
Best I can tell, the main difference between the 1000 & 3000 system is where the fittings are placed on the back to go through the firewall. Were these located where the fan box hole was on your firewall with the 3000? I was looking at the Classic Air unit a couple others have used, this one looks to be shaped better and I like where you mounted it (think I have even less room in a 55). Where did you put the cable pulls?
Thanks!
Tucker
Cool - thanks for the tips. Will probably be tackling this over the winter, most likely the same route you went since I'm running a MB diesel and need to go with a Sanden compressor. You just need a condenser, expansion valve, and dryer outside this kit correct?
Tucker
4.29 gear
what kind of fuel tank are you using
good move for bosh III injector, did you take them at South bay injection
