i dont know which one he has...maybe he can post up the part# from the original reciept...i do knotice that it has a black cap on it and looks to be a DUI:
Performance Distributors - High Performance and Racing Ignition Systems
however...the one on the site for a toyota 6 is a blue top
he can bring it to any auto zone or place like that and have it tested as they do for an HEI...that would rule out the coil and ign module if it checks out.
where it was said that theres a voltage drop is interesting....as a dui needs 12 to work right
so far if i were you
(thank goodness i'm not him i think i would loose my ramaining hair and start drinking and smoking again) I was just thinking this right? or did i type that out loud
i would check this laundry list of things out
doesnt matter which you try 1st...just do it
1) check the fuel pump? flow to the carb?
2) take the regulator out of the equation? how does it push after the regulator? go right to the weber from fuel pump
3) try a temperary wire direct from battery to dui + power....(this is only temporary!!!) you must remember to remove the wire after you are done testing...you dont want 12v constantly to the hei/dui....you'll burn out your ign mod!!!
4) you can remove the dui and bring it to most every auto parts store for them to test also
5) you could also try and remove all fuses from fues block except fueses to run and then test
6) try and put your hand over the carb and block the air going in (makes it rich and compensates if the choke is inop)
7) also try pouring a little fuel in and see if it accels? (tool lean)
8) also you might want to try starting with it floored and see if it will fire at all or just turn over
PS kidding about the drinking and smoking thing
sometimes i like stupid humor
