Sorry rsbcruiser for volunteering your parts, just was figuring your dizzy is known to be "good" and a quick swap to see if jdog's truck ran better as a result. At least we would know if it is the dizzy or not. I'm thinking it and the coil is the culprits.
i dont know which one he has...maybe he can post up the part# from the original reciept...i do knotice that it has a black cap on it and looks to be a DUI: Performance Distributors - High Performance and Racing Ignition Systems
however...the one on the site for a toyota 6 is a blue top
he can bring it to any auto zone or place like that and have it tested as they do for an HEI...that would rule out the coil and ign module if it checks out.
where it was said that theres a voltage drop is interesting....as a dui needs 12 to work right
I might have misunderstood jd here
so far if i were you(thank goodness i'm not him i think i would loose my ramaining hair and start drinking and smoking again) I was just thinking this right? or did i type that out loud
i would check this laundry list of things outdoesnt matter which you try 1st...just do it
1) check the fuel pump? flow to the carb?
Checked it and it's fine
2) take the regulator out of the equation? how does it push after the regulator? go right to the weber from fuel pump
3) try a temperary wire direct from battery to dui + power....(this is only temporary!!!) you must remember to remove the wire after you are done testing...you dont want 12v constantly to the hei/dui....you'll burn out your ign mod!!!
4) you can remove the dui and bring it to most every auto parts store for them to test also
5) you could also try and remove all fuses from fues block except fueses to run and then test
6) try and put your hand over the carb and block the air going in (makes it rich and compensates if the choke is inop)
we did this, no change at all
7) also try pouring a little fuel in and see if it accels? (tool lean)
same here, no change
8) also you might want to try starting with it floored and see if it will fire at all or just turn over
PS kidding about the drinking and smoking thingsometimes i like stupid humor
Is this one acceptable:
FJ40 FJ55 Toyota Land Cruiser Voltage Regulator - eBay (item 320620601301 end time Dec-21-10 13:28:36 PST)
And this was listed as well but I'm not sure it was on the 'check-list'
FJ40 FJ55 Toyota Land Cruiser Ignition Cable Switch - eBay (item 320623104526 end time Dec-27-10 09:37:20 PST)
Thoughts?
Might be a long shot, but what about a chassis ground. The ground from engine to chassis.
Neil.
Take the coil with you too and have that tested as well.Pull the whole dizzy out and take it w/ you. Then you'll have everything they might need to test it.
Geez...This thing is a real nutbuster!
