craigslist 1973 Toyota LandCruiser FJ40 - $16,900
Status
Not open for further replies.
oakweb
GOLD Star
Las Vegas
Year
1973
  1. 40 Series
=========== NOTE - These are not mine, contact the seller via the Craigslist Ad =================
1973 Toyota Land Cruiser FJ40 - $16,900 OBO
Super clean, fun to drive 1973 FJ40, has clean title with matching numbers to engine and is a great candidate for a body off restoration. Garaged for the past 20 years, paint has been touched up with too many new parts to list.
STATS
Color: OEM Dune Beige
Engine: 1F Motor 3.9L straight 6
Transmission: 3speed manual with Hi/Lo 4x4 transfer case
Carb: Holly 2 barrel, comes with Weber carb conversion kit ($500 value)
Miles: odometer reads at 40,798 but likely is higher, actual miles are unknown
DETAILED INFO:
Engine: rebuilt with new bearings, rings, gaskets and seals, rebuilt head with new springs and valves (5k miles ago)
Exhaust: single piece custom header and custom exhaust
Clutch: replaced with engine (5k miles ago)
Ignition: CraneCams FireBall XR700 ignition
Rear End: rebuilt with new ring and pinion, gaskets/seals (5k miles ago)
Gas Tank/Fuel Lines: new poly tank, fuel lines compatible with modern fuel additives, functioning expansion tank and charcoal canister
Electrical: all wiring has been traced, repaired and re-grounded as needed, re-wired rear main harness, new fuse block, new LED tail lights and brackets, late model front turn signal lights, all side marker lights and in dash lights work, OEM dual horns, new battery cables with fusible link , blasted and coated battery tray
Heater box: refurbished heater core no leaks
Cowl Vent: new rubber seals and hoses
Soft Top and Doors: easy to lower and take the doors off in minutes for an open air ride without the hassle of removing a heavy metal/fiberglass top and doors, no hard top
Front Bumper: custom front bumper with winch mount
Solid Tub: tub is solid but has rust in the usual spots, a great candidate for a body off paint job, whole interior cleaned and treated with POR-15 product, rear bottom sill has the typical rust but isn’t rusted out, has OEM running board on driver side, missing passenger side.
Interior: Toyota/Lexus driver seat installed, matching passenger seat comes with the car as well as the OEM seats that need to be refurbished, all dash knobs and trim are complete, original upper and lower dash pads, new shift boots, shift knobs and powder coated transmission hump, new gas, brake and clutch pedal rubber
Rear Doors: half doors for easy access with the soft top
Rear Seats: rear black vinyl bench seat that faces forward instead of the jump seats that face sideways with new seat belts
Brakes: Replaced Master Cylinder, Clutch Master and Slave cylinder, new brake shoes, new stainless steel flex brake lines throughout, needs new brake power booster
Windshield: new glass and rubber seal
Roll Bar: late model OEM roll bar with 3 point seat belts mounted for maximum driving comfort
Extras: Includes passenger side Lexus seat and OEM drivers seat, Saginaw P/S gear box and frame mounting plate, OEM seat brackets, OEM center console, spare starter motor, and lots of odds and ends that go with the vehicle.
No trades, cash only, call or text with questions.
Clean Washington title with collector plates to save on registration
Email, Call or text Jeff at 2zero6 Five7Nine 5NineTwo9
Keywords: Toyota, LandCruiser, Land Cruiser, FJ40, 4x4, off road, TEQ, Jeep
more
more
Status
