1968 fj40 resto
Hi Friends Im back!!
have a question on the front brake tree way block
if the metal line get stuck on his way out after get unscrewed, how do i take off with no damage on the treats??
It’s a double flare, usually the line is soft enough you can pull it out if the fitting spread it. As old and brittle as that is, all bets are off. Have you tried rotating it with the threads to screw it out?
Hi Tuker, yes it is all scwed out, but I think the line is stuck ( open end) cause a overtight!
He means rotating the line itself, as if it were threaded? This works for me…occasionally.
When it doesn’t, I go to the shelf and pull out a good one. :grinpimp:
I always enjoy a challenge. First with the nut thread all the way in would sand line with fine emery cloth. After unscrewing nut out wire brush the threads. After getting it as clean as possible with the fitting threaded a coupe threads in wrap the line right at the fitting with electrical tape. Put a visegrip on the tape. Now while hold the visegrip to keep the line from turning unthread the fitting. This would act as a puller. If the line is rust to the fitting at the flare it may tear. Something to cut rust and heat to the fitting may help. If the line ends up tearing would use Mark's plan B and grab one off of out of my junk pile.
It's usually the 9mm fitting that has spread from being over tightened. Once you're past the threads, just grab it with some pliers or vice grips and pop it out (it's probably junk anyway). It might bugger a couple threads in the three-way, but usually not an issue.
Good idea thanks !! I will try to do that!!
^^^^^^This^^^^^ I've run across the same thing with 10mm fittings. The bottom of the fitting has spread out from tightening.
step two, than I call Mark , for a new one!!:bounce:
I try to do the pull out and it was hard, so I went on option 5
use the drill and dremel, hole time to time until the wall get thin , I dremel a noch all de way in bouth sides and jus bend and pull it out!!
sounds easy but I was left with burrs on my fingers, and all my clothes with burrs too.
tand I sand blast it ansd garlvanece the piece
That’s CRAZY Frank! I I’ve never seen a Landcruiser frame INSIDE ANYTHING! That’s gotta be photochop.😛
hi Mark !! no photoshop
Its mather of faster cheaper and control it! hehehe
thanks!!
Very shiny Frank. Two things. I would be concerned that plating the engine mounting insulators would compromise the integrity of the rubber. Second, did you test fit the front bumper already? Because that small wave in the left frame channel behind the center arm pivot could very well effect how the frame holes and bumper holes line up.
