BURGER said:Have you fixed that yet? Mine is driving me nuts!!!!
Burger:
Not yet...I'm so used to it it doesn't really bother me too much anymore. Been too lazy to crawl underneath there and see what washers I need.
Milo said:The reason that it doesn't comfortably sit or overtake at 110km/hr is not because it is hitting it's rev limit but that it doesn't have the power to push the vehicle along any faster than 110 or so. The revs sit at a nice level (guessing about 2500rpm) at this speed. So more power and torque at the same speed will do the trick. After all, I don't need 200+km/hr out of it.
I can easily pick up a scrapped 1HZ for free being that I am in the mining game out here in the Goldfields. HZJ-75s are almost as common as flies around here. But it would need rebuilding and could well be beyond saving. However a brand new or recond motor will still fetch around 10 to 12 grand Australian. That tends to make the 13b-t look amazing at the price of 5.5k.
I do a lot of my serious driving down on the beaches around Esperence where we have some of the softest sands anywhere. The extra torque is a god send because it stops you from slowing down. That way you just chuck it into a higher gear and just chug along using bugger all fuel. If you have to rev the guts out to keep going (using the power rather than the torque) then you'll use heaps more fuel.
As for the 12HT, I am NOT putting one of them in my shorty. Are you sure you didn't mean a 1HDT?
All in all, I just like the way the 3b drives. A nice square little motor that produces heaps of low down torque. This is why the 15b-fte would be so good.
roscoFJ73 said:Yep ,I meant the 12HT.whats wrong with those?
R2HKS said:My 42 though has no troubles doing 110km/hr in fact it cruises better and quieter at 120km/hr and I have had it as high as 160km/hr just to see what she had. It ran well to at that speed, very stable, probably because I have the rock hard Rancho RS 5000's in it.
Stone said:Oh yeah? What were your EGT's at 120 km/h and then at 160 km/h? I've never taken my 13B-T up to 160 km/h (I doubt I would make it there), but at 130 km/h my EGT's get fairly hot even on flat ground. (H55f, 4:11, 255/85r/16).
Stone said:To tell you the truth, I don't like hearing my engine hit 3000 RPMs and that probably is more the issue here.![]()
Stone said:After listening to my PTO winch lever rattle all day, I don't think Greg could be convinced to trade his factory Toyota 24V winch for a PTO.![]()
roscoFJ73 said:All good reasons then,but I had a 1HZ rebuilt in Perth for $4800 using an OEM rebuild kit plus $1500 on the pump which wasnt budgetted.
Milo said:Unless the 12HT is significantly different from it's non-turboed brother I would tar it with the same brush.
Do they? I thought they bolted to the M152 trannies? Same bolt pattern but different input shafts I think.Dave said:15 15 15
Get it!
Do it!
Get the 15B-Ft.
Install it. Bolts right up to the tranny.
Greg_B said:Piston oil skirt cooling on the 12HT...which the 2H does not have.
The 2H seems to crack rings, and I have not heard any such problem with the 12HT.
Oil skirt cooling: All the difference, and probably one of the reason the 3B is such a stout little motor too.
hth's
gb
R2HKS said:Do the 3B's have oil squirters for the pistons? If so saweeet! Main difference between turbo gasser pistons and atmos are the turbo's are oil squirters to aid in cooling. Even better reason to turbo the 3B!
