12H FJ60 Project
That thing is sweet! Powdercoat looks amazing!
Nice work. Were did you source the rear sliding windows from?
The engine compartment is mostly finished short of a throttle cable. All of the cooling, fuel, PS and dual battery systems are finished and installed.
The AC condenser, drier and custom hoses are finished and installed.
We installed a Toyota Turbo tach in the stock location and also installed the Pyro Gauge into one of the vent holes. I aslo installed a Wagon Gear Dual antenna to run the new CD player as well as the CB which is in the center console. I alsi installed the Sirius antenna on top of the snorkel.
Aux fuse panel installed in the Tuffy along with the antenna splitter and the CB. The switch on the front of the console is for the rear air compressor. I also installed a Hellroaring battery isolator on the fender well to keep everything separated between the Main and Aux batteries.
Cellica seats installed as well as the Puma Air compressor to supply the rear ARB as well as provide air for whatever else you might need.
It's just dumping out of the turn down off of the turbo now. It does sound good and not that loud. I would be hard pressed to run anything other than a straight pipe out the back but it will likely end up w some type of muffler.
Wow! I am going to definitely have to come by the shop and meet you guys. Very clean install. Sounds amazing too.
I was lucky enough to see and hear this rig last weekend. It was nearly complete so it may be gone now. I know if I find the right diesel for my 80 I'd just take it all to ACC and let it be done right the first time.
Awesome. That factory tachometer just seals the deal for me.
Very nice work.
