I just wanted to post my solution using a pigtail off the wiring harness under the console on my 1997 LC that fit the Matrix Switch. I've outlined the proper wiring below to show how to hook up the switch to run any inverter and also have the 115V illuminated with parking lights and also get the power light to wok on inverter activation. - This setup allows for inverter operation without the need to have Acc or Key On power to the truck
Non-Relay
#1 Wire Blue w/ White Stripe to Negative Battery
#4 Wire White W/ Black Stripe to Cigarette Lighter / parking light Illumination
#3 Wire Dark Blue w/ Black Stripe to Positive Battery
#2 Wire Green to Negative Battery
#6 Wire Blue w/ Orange Stripe to Inverter Switched 12V Input (Activate Inverter)
The above provides switched power to the #6 wire with On/Off Light when switch is activated
The above provides the 115V Back Light when the parking lights are activated.
I recommend using a Relay
#4 Wire White W/ Black Stripe to Cigarette Lighter / Parking Light Illumination
#3 Wire Dark Blue w/ Black Stripe to +/positive from Relay Switch Wires
#2 Wire Green to -/Negative From Relay Switch Wires
#6 Wire Blue w/ Orange Stripe to Switched 12V from Relay Switch Wires
Video of the switch operation:
Hope this helps someone~
