#11 Dune Beige bodywork and paint 40 series
Looks great! The lead work looks way better than body filler.
I’m curious about this technique. Off to the googles I go…
Lead sleds, late 40’s and 50’s modded cars. Was taught in HS shop class years ago (In the land of Nod)..😎
All my friends know the low rider
The low rider is a little higher
The low rider drives a little slower
Low rider is a real goer
Low rider knows every street,
Low rider is the one to meet,
Low rider don't use no gas now
Low rider don't drive too fast
Take a little trip, take a little trip
Take a little trip and see
Take a little trip with me
Roll bar brackets. These were wasted, so I soaked them in acid, sand blasted them. I made some new plates where the bolts holes and weld nuts are located. I cut the rusty parts off, welded the new metal on and drilled the holes. I need to clean up some of the welds, and attach weld nuts, but they look good.
Almost everything else is ready for primer now. Lots of small parts that had to be prepped and it took all week. One of the rear doors has rust, and today I started working on it. The other door looks pretty clean but I will cut the bottom off of it also to be safe.
Finishing up this door rebuild. Sandblasted the remaining rust off the inside and welded the new part on. Now I will make the skin piece and attach that. Everything is coated with zinc primer on the backside and will get cavity wax afterwards.
Beast mode activated
WOW! One of my favorite things about this forum is seeing the absolutely amazing skill sets some of the members here possess!
Thank you for sharing!
