“Definitely options for the 1FZ as Mike helped to make the adapters. The N63(v8) adapter is 45mm vs 20mm for the UZ adapter. If you go with a ram transmission as that’s more plentiful in the US it’s still about 45mm for the adapter to the engine but the transfer case adapter is longer at I believe 147mm.”
Papa Wickey,
I am confused, my old age forgive me…
1FZ vrs UZ adapters. I think I understand the engine to BMW 1FZ is thicker than the UZ? Do I have that right?
I know the flywheel really set back deep in the bell housing in my LC80 1Fz compared to my 100 UZ.
My 80 has a longer transfer case over all length front case mounting to rear flange too. This is to accommodate the VC viscus coupler.
Please correct me if I am off base,
Using the dodge trans 70-75 series from the ram pickup like Mike I believe did, domiworks said a 1Fz with that two piece transfer case adapter, makes my transfer case set back 2.859 inches compared to my A442 lengths…
I don’t have the room to move my transfer case back that far using a Dodge 8HP.
Now you guys come along and using BMW transmissions, the transfer case adapter is thinner !
TrailBornRunner measured the BMW to adapter face as 27.625 dang close but the 1Fz engine adapter isn’t 20 mm is it it’s thicker 45 mm for it. 1.77 inches
27.625 plus 1.77 =29.395 - 28.125 old a442 leaves 1.27 inches on it set back on my lc80 better that the Dodge transmission. My 80 transfer case is longer, I wonder it ifs possible to move the input from the 80 to the 100 transfer case like I did doing my under-drive gear swap , changes the input to an 80 series with a pressed gear. If I remember correctly to install in the the 100 case this would shorten my overall length by 1-2 inches using the non VC coupler transfer case. I have to crawl underneath the trucks and measure the 100 to the 80 transfer case.
I still have my old 100 input shaft and gear set that had to be removed. I have to review pics and old gears to refresh me memory.
Trailbornrunnner measured his A343 at 27 3/16 - 27.1875
UZ “20 mm” .787 plus 27.625 BMW with Adapter is 28.412 overall length
1.225 inches setback on my 100 it appears.
Please check me and see it I am on target. Both of you are facing that challenge… me too if I undertake it. To used the New Thinner adapter to BMW transmission to transfer case it required an input shaft swap. The 100 I think the gear is all made together where as the 80 it’s two peace’s.
Here is the Transfer case from an 80.. zoom in on input and see a snap ring … pressed on gear.
Second pic is the 100 with new input shaft and gear has that snap ring too, last pic is the 100 in stock form no snap ring gear and shaft made together.
Papa Wickey,
30.984 inches total compared to my A442 1FZ to Transfer case is 28.125 inchesAdapter kit is 45mm
Transmission is 616mm
Transfer Case adapter is 126mm,
