100 Series General Tech and Classifieds
Damn man that seems like a steal at that price. Seems like you could keep as is and just make it a budget wheeler.
Interior looked clean too. If someone half asses this I will buy the seats and give you mine from my 98.
Got the 100 torsion bars sorted out. Rob's advice was spot on. Ended up with 1 1/2" lift front and back. Still have right at 3" droop. Doesn't look too high but remember the tires are stock size.
Not too much detail but:
Drop old torsion bars.
Place new bars into key or rear mount with just a couple of threads of the bolt holding them in.
I slid the a arm ends of the torsion bar back past the splines.
Pull down on the key or rear of the torsion bar.
Turn the a arm end until it lines up with the bolts on the a arm and then about one spline past (puts a bit of tension in it but not much).
Slide the a arm end mount back onto the splines and bolts.
Tighten down the nuts on a arm.
It took 14 full turns to get the key end bolt tightened up to get the correct amount of lift.
I don't know what this means, but I'll read it again when I do mine.
Now I want to get a 100 and go overlanding. ****. All of these options.
You would not know what to do with a/c and space.
