Wanted 100 series climate control panel
Missoula Montana
  1. 100 Series
  2. LX470
My factory navigation unit that has climate controls built into the screen doesn’t work. I need a climate control panel to separate the climate controls from my head unit so I can get an aftermarket head unit.
My head unit says no disk detected and won’t let me do anything. If you know what this might be let me know so I can possibly get my head unit to work while I search for a climate control panel.
what year?
I've got early ones in Helena with pigtails to splice in
I'll dig them out tonight or Sat.
Paul
I've got these 2, top one is a 98 bottom is a 99 both had rear air
I think I'll be thru Missoula next Sat.
I will definitely want the bottom one because it has the pigtails I need. I’m 17 and have little wiring experience so this will be quite the task. Also I just learned that the nav head unit brackets are different than the non head unit brackets. Do you have brackets from a non nav head unit?
the pigtails can go with either one. the top one has a nicer finish than the lower one. you can pick which one.
I still have a 100 parts rig in the shop, I can look and see about the brackets
Ok awesome. How much would you take for one, do you want more for the one with the nicer finish?
I do have radio assembly with the side brackets. I can bring them along with me on Sat.
