100 series build
I found a fridge on local ETTO facebook page in East Texas and it was at a great price so I picked it up. Has worked great so far but needing a fridge cover and potentially needing to cut so insulation like used in a deer stand at get it put in the rear windows although not ideal I think it would help a great bit...... and no im not talking about the rear window but the two on either side.
I added a double USB on the bottom half of the center dash beside the ashtray.... This is mainly for folks riding along that need a quick charge. I will be adding a double usb OR the Anderson Powerpoles to the back seat where there is a cutout in the center console above the cup holder. The Anderson Powerpoles I will use for my Laptop as I need it often while on the road and it is an easy connect and disconnect. I will just buy a new charger and rewire it to fit the Anderson Powerpoles since its a standard 120 currently. I am doing that due to the easily coming undone 120 plug in. That being said I will add Anderson Powerpoles in the back to run the fridge I showed above along with other things. I will also add a Blue Sea set up in the back on one side to accommodate a usb and a 120 plug incase we need it for others not using Anderson Powerpoles.
