My 06 started throwing P2440 and P1441 at 155,000 miles. The easiest part of the hewitt bypass kit was the block off plates. Remove the front wheels and then a skirt of shorts is all you need to remove to have access to the exhaust tubes on the 100.
The shop vac noise for 30s-1min is very common before a full pump motor failure but it is not always the case.Im dragging my feet on this. Do you normally get a fair amount of high pitched whining prior to failure?
After doing some research regarding the bypass module, it seems that some users are reporting a P011B error code in warm weather resulting in a CEL. This appears to be mostly on 5.7 motors and using the current eBay seller's plug and play module.
I found out about this after ordering the module. While I don't have any issue with my Air Injection Pump at this time, I wanted to be prepared should the situation arise. Do you presently have any issues with your bypass?
The starter relay wire simply ensures that the module is activated when you actually crank the vehicle so it can prevent the system from running. Our current modules are activated when you first turn the ignition to on and then again when it senses the ECM signal to the starter relay. This is mostly a "just install it" and don't worry about having to always crank the engine immediately from the off position.If you used the plug and play why the need to connect a wire to the starter relay?
so, I'm sorry, I read and searched a little more and found the hewitt page with lots of code
Codes
good read.
IMHO it seems a bit too much money to clear a few codes when there are at least 20 or 30 more that relate.
But I'd gladly pay someone 500 to eliminate an entire SAI system from monitoring. How could I accomplish that?
Mine just happened at 160000I just read all the posts on the tundra forum. This is interesting. Does anyone else have an 06-07 that has had this issue? just curious at what mileage these failures are taking place?
I just ordered a bypass kit. My Toyota master mechanic friend said he could do it for $795 but I would rather spend $179 and bypass it. He sells factory rebuilt units on eBay if anyone is interested in doing this repair. What are your thoughts on it?And you did ??????to repair it
CopyWhen the time comes I will also do the bypass.
Posting up on your install would be appreciated.![]()
I don't like that I hardwired it. I wish I would have went with the plug ins. I would rather be able to undo the thing and put back to stock quickly to do any diagnosing or repairs. Interrupting the IAT might make it harder in the future to fix any issues.
On the few cold start, cold ambient days down here I could definitely tell something different was happening regarding idle. In all other conditions, I can't tell it's there.
which was different from the one sent with the control module. I'm 100% I wired it like this picture.
