How to bling a 2F valve cover
Biscuit
Mars Rover Driver Emeritus
Boulder, CO
So today I decided to clean up and then polish the 2F valve cover I picked up from Mark earlier in the week.
It started off as your ususal used 2F valve cover.
With the ususal PO gunk on it:
To prepare the valve cover I first cleaned it with some soap and 409 to get the grease off. Once it was clean, it was time to get the crap off it, which means lots of sanding. I started with 320 grit, followed by a round of 600 grit, and finally a quick run of 1500 grit. This actually cleans up the valve cover pretty nicely.
I decided to polish the valve cover rather than paint it, since it is Aluminum. I used Mother's metal polish, and I did it all by hand. No power buffer used.
The finished product
All said and done it took me about three hours. Individual results may vary.
I'll be installing it later today or tomorrow.
just get some of that wire scrubbing stuff and that polishes it up pretty nice
:doh: I forgot the ever critical time issue. It took me about 3 hours start to finish (if you don't count the run to OSH to get the poilish and more 320 grit).
The ammount of time you spend on it it directly related by howmuch crap you have to sand down. The epoxy like stuff in the second pick took the most sanding time.
The raw aluminum stains with ANYTHING, and oxidizes as well. I polished my first one and cleared it with some urethane.....well, it does not stick, part has come off in sheets. If you etch it, it will darken, but at least the clearcoat will stay on it. My current cover is bead blasted, etched and cleared....
Ed
What did you etch with, because that is one nice looking valve cover.
(And apparently I'm not the first person thinking about the 1.5" TEQ blister sticker on the front)
3M metal prep, IIRC. Most are some blend of phosphoric/hydrochloric acid.
Once etched, I just used a catalized clear urethane. I just wanted to have some coating that would resist staining. S'pose you could have it anodized, or powdercoated.
Ed
BTW....thanks for the nice comments. I hope it holds up OK.
i just polished my valve cover it looks sweet shins like a mirror. maybe this will get me to clean my Eng more often then every 2 years. good job MR.biscuit. BTW this guy has one nice 40:grinpimp: !
I did something similar, except after sanding half of it I said eff it and Just wire wheeled the whole thing, then used a buffer wheel with an alum polish on it. Porlly should clearcoated it or something but ohwell, eventually everything is gonna get ripped out and cleaned one by one anyway
John, I predict that NOTHING else on your pig will EVER look as shiny as that valve cover! ;p Of course, your rebuilt carburetor comes close.;)
Biscuit, that 'patina' you so carefully removed came to Kali from noneother than Lancaster, Ohio! IOW, that's some well-traveled dirt!;p
Nice job.:cool:
Those are all looking really nice. Ed, yours almost looks like it was painted grey, I dig it.
Oh and if anyone would like one, I have an extra 2F cover lying around that I need to get rid of. :D I think it might fit on an F head with the right studs. Correct me if I'm wrong here please. Hijack over. :doh:
Um, yeah, they all look good fellas. :beer:
Put it in a box and send it my way....
:beer:
I wet sanded mine with 400 grit and then on up to 1500 grit, then used some mothers aluminum polish, looks good for about two years now.
Not as bling as Degnol's man that looks sweet!
Rezarf <><
Ed
Please educate me. What waterpump fan is that? Will it fit a 78 with a fan clutch?
AFAIK, all the 2F clutch fans/ clutches/waterpumps will interchange. This particular one is off of a FJ60. Bailey picked it up for me at a PnP.
GL
Ed
If you use a spray laquer on the cover it'll eventually gain a slightly golden hue.....THAT would be bling.
