Bringing an FJ back to life
Purchased my first FJ80 from an auto auction in Arizona in October of this year. It's a 1993 Land Cruiser with 64,722 miles on it and factory lockers. It had been wrecked in the front passenger side and has a salvaged title. The auction said it started but didn't drive due to fender and bumper impacting passenger tire. I didn't have a chance to go view it in person before the auction date so I bought it without inspecting the damage before hand, just going off pictures. I ended up getting it for a good price which I thought was cheap enough to risk whatever unseen damage may exist. Here is a picture as it sat when picked up from the auction yard:
Once I got it home I pulled all of the damaged bits off and created a list of parts needed to bring it back to pre-wreck condition:
*Passenger Fender
*Hood
*Bumper
*Passenger Headlight, corner light and blinker light
*Valance
*Passenger side core support baffle
*Passenger side fender apron
*Power Steering Gear box (Sheered the sector shaft when wrecked)
*Relay Rod
*Front Lower control arm (bent)
*Axle Housing (turned out the axle housing was bent)
*Rebuild kit for axle
Carfax shows that it was sold new in Sheridan, OR and later moved to Sedona, AZ. I have absolutely zero service records but I did have a sticker in the corner of the windshield from RedRock Precision Motors in Sedona indicating it had had the oil changed just under 3000 miles ago. I tried calling but they weren't able to provide any info based on VIN. Checked all the fluids and everything looked pretty good. Changed the oil and spent the rest of the day trying to get it started with no luck. Drained the gas and added fresh, still no good. Found the handy Repair Manual PDF available online and started troubleshooting. Turned out to be the fuel pump was bad. Dropped in a new one and it fired right up.
Old fuel pump:
Runs really well, no engine lights, no funny noises and no leaks. It does idle at 2k rpm when starting up which I thought was a bit high but not 100% sure, is this normal?
At home after puling everything apart the first weekend:
So between the first weekend and now, I've successfully rebuilt the power steering gear box and upgraded to the 105 series sector shaft. (Thanks to forum member Akella for the sector shaft and rebuild kit) Replaced relay rod and rod ends. (I did all of this before realizing how bent the housing was, I would have waited to install everything later if I knew...
)Purchased fender, hood, valance, bumper, baffle and axle housing.
Picked up the axle housing from another member on the forum and just got it cleaned up over the holiday weekend. I'll continue to post updates as I go, it's been pretty slow going so far...
Someone ground down the backside of the bearing races a little bit, maybe to help get the old one out, not sure...
*Passenger Fender
*Hood
*Bumper
*Valance
*Relay Rod
Old fuel pump:
)Purchased fender, hood, valance, bumper, baffle and axle housing.Picked up the axle housing from another member on the forum and just got it cleaned up over the holiday weekend. I'll continue to post updates as I go, it's been pretty slow going so far...
