Hey Guys, I need some new door hinge bushings all around, does anybody have the the measurements for them?
Thanks in advance
Thanks in advance
You can buy them from MAF, SOR, CCOA and a number of other companies that specialize in 40 parts. Yes, you can take the measurements from the bushings and buy headed bushings that are made from superior plastics from companies such as MSC Industrial Supply, Enco or McMaster-Carr. If I can find one in my shop, I will post the dimensions. I'm sure there are a number members that can locate one and post the dimensions.
Here are the measurements for the brass bushings:
bushing OD 0.380"
flange OD 0.628"
bushing ID 0.310"
flange thickness 0.0425"
OAL .400
I think the only critical measurements are the ID and OD and the flange thickness so it fits in the hinge
If you can find the proper bushing with the proper flange for a dime be sure and let us in on it.
if you loose one.Will These work for the ambulance door hinges as well?
