Hi guys
Had new motor installed, was tuning and chanign the points, and a damn screw fell in the distributer, so i had to pull it.
Sorted it popped it back in all good, turned the motor off, and as i was tightening the advance retard handle to lock it in place, some old dude started me as i was bent over the hood and i dislodged the distributer, no biggy.
One this that did happen was the side negative coil wire that connects to the side of the distrubuter, was brittle and broke so I had to splice it together... ( which could be my problem.)
But to make a long story short i put the distributer in both ways ( rotor shaft that sinks into the oil pump one way and the other ) Both ways will not start, one turned over and caused a back pop outta the tail pipe, the other outta the carb...
I made sure the distributor was seated completely both times )
So is it that i just need to replace the negative coil wire from the coil to the side of the distributor?
Is there a way the flywheel and the oil pump cog can get out of sync ( truck rolled an inch when the distributor was out cause the old man leaned on the truck cause ing it to roll
so negative coil wire?
distributor 180?
something outa sync?
Sorry if this sounds dumb but I cannot figure it out
thanks!
distributor 180?
thanks!
