I would like to remove the PO bumper and re-install an OEM bumper. Think I can simply grind off the welds and I will be set?
I know this is off the subject, but what springs do you have there? The shackle angles don't look good.
To reinstall the OEM bumper, you'll need to source the triangle pieces to attach the bumper to - 1 on top and 1 on the side of the frame for each side - 4 total. #5, #6 and #7 in the below pic.
I don't blame ya. I'd want to get rid of that bumper also. You could also look into making your own bumper. Lots of ideas and pics here on mud.
Hard to tell from the pic, but did he weld over the vin number???![]()
Why would that matter? The VIN plate is still on the door sill and the VIN is stamped elsewhere on the frame.
i think the one on the frame is more important, don't qoute me on that. body's can be changed, i think the dmv wants the correct frame/title combo.
edit: you should be fine. just be careful cutting the bumper off. be careful if you repair that little hole in the frame on that horn. looks like your vin run directly on it or just above it.
Where else is it stamped on the frame?
Shawn
Shawn
Can't remember exactly but I have seen it several other places on the frame (when was comparing it to my non-original engine).
Already had cop come out and inspect the vehicle before registering it here in GA. He simply looked at the VIN plate on the door sill.
Yep - it is the VIN plate that needs inspection, not the engine numbers or frame numbers. Not sure if this varies by state or not but most it is just the plate.
Also, doing the frame off and sand blasting and painting the frame, I never ran across another number on the frameMine is a '72.
