What about the 3FE's? Do I need to add ZDDP, or is it fine without it? Sorry if I missed the answer to this one in the previous 18 pages.
Thanks.Yes because the 3FE is the same basic design as a 2F.
It isn't that expensive really, a good Mobile 1 oil cost from 20$ a litre and up. That is expensive!
OEM filter is another 50$ at the stealership, cost to take care of these nice trucks, but it is also worth it
If I opted to cheap out I could had bought some cheap low quality 10w-30 mineral oil for about 6$ litre in 10L cans.
With such a low warm viscosity rating, don't you have trouble with well enough lubrication at engine running temperatures?
I know modern diesel engines starts to use long durability 0w-30 oil, but those engines also runs a lot more efficient and doesn't produce the same amount of heat. The 2AD-FHV (2.2L diesel) in my brothers Avensis uses 0w-30 Toyota oil at each change.
I run Mobil1 10w-40 with a bottle of ZDDP in the winter, and Mobil1 15w-50 with a bottle of ZDDP during the summer.Sorry for the constant dumb questions on my part.
But I live in Connecticut.
The temp range in winter is about 15-45F. Rarely gets below 20 but it does sometimes.
What is the thickest oil you would run in winter?
Is 15W-50 too much?
Or the Rotella 15-40?
Sorry, not how viscoses, but how well it lubricates. A lower rated oil will loose its ability to lubricate at a lower temperature than a higher rated oil if I am not completely wrong.I thought the second number in the rating told how viscoses an oil are under high temperatures.
After reading through this thread, I dumped Rotella 15-W40 into my 3FE along with a bottle of ZDDP+.
