I know it's been beaten if not to death at least into a coma and I have searched and read.
220k miles. I've only had a year and haven't driven it much because I've been slowly doing things to it. Suspension, brakes etc.
Well starting to drive it a bit it's got late hard shift points. 1-2, 2.5 to 3k and shifts hard, 2-3 if you let off the throttle a little at 3k it'll shift.
The above got me searching and reading here. I've Rodney flushed, run about 5-6 gals through it and fluid looks good, never looked burnt but was dirty. I've cleaned the strainer/screen minimal debris, magnets had a film of metallic particles but nothing not expected.
I've adjusted the throttle cable/kick down, still playing with it a bit.
The above made it better but still pretty close to the same.
Party trick but only at about 35mph
Options at this point???
I'm going to run the throttle/kick down until it's obviously too lose the tighten up a turn o r so at a time and see if that helps.
Any other ideas ???
Party trick at 60mph or so ???
Just give up and face the fact it needs a rebuild??
Ballpark cost to rebuild if I pull it out vs just drive it to a shop??
Any other ideas ???
