asutherland
VA7 HDT
I've noticed how my power steering is affected by the warm summer temperatures and larger tires. In the winter, with my smaller tires and cooler ambient temps, it behaves way better. I've done a bit of research on here and decided to install a small oil cooler in line with my "paperclip" style oem power steering cooler.
I wanted something small, and something Toyota. I found a 8 x 5 inch Toyota ae86 oil cooler that fit the bill. Cost me $20. Plus now I can drift
It was nearly a perfect fit right out of the box. I had to make a couple small brackets, a couple adjustments of the stock one, and now it fits perfectly and is very steady. The ATF lines will go down under the rad and join in to the low-pressure PS return line. (tomorrows job).
And yes, if you were wondering, that is an FJZ80 oem transmission cooler on my 1HD-T you spotted in one of the pics below.
