You can tell I'm new at posting on a forum... I'm going to investigate the off-boost screw. The wire has been cut by po, I think fuel turned down to compensate for the clapped out ct26 on there before.
It's early days for me regarding these motors, I'm happy to say I eventually wound the main fuel screw 1.75 turns, drives cleaner and smoother with more torque. The motor seems happier too, it fixed up the delay before boost fuel kicks in. I get to drive it with less downshift. Eg is about the same on cruise but 100c more on full load. Gear changes are smoother too.I think this thread has shown Gturbo is as close to perfect as is available, but with a price tag to match.
Of the two above, I think I'd opt for the td05 7cm one. The ad doesnt specifically state what platform the CHRA uses? Assuming its gtx CHRA with ct26 housings?
Based on discussion here, I asked Mambatek if they could supply a version of this with an 11blade turbine for better efficiency and better low end. No such part is available.
Having said all that, I have a used ct12b/hdfte turbo I'll be putting to use at some point. Price was right! Turbine design is also not ideal, not as efficient as newer options.
But I have collected almost all parts needed to fit it up with Supra front housing and install it.
I'm working with a turbo builder over here (the one who built my Garrett GTX) to develop a hi flow CT26 safe for 50+ psi with response similar to or better than the GTurbo BBX.
He seems to think it's a feasible possibility. I'm happy to be a test pilot. He'll send a prototype, I'll bolt it up, do a dyno run, get some back pressure readings and go from thereHonestly, there's no point and it probably won't happen. 50psi from a single stage compressor is pointless as the operating range between surge and choke gets very very short and efficiency is sacrificed for pressure ratio. If you want 50psi then you need compounds.
Have run 30+ for 18 months now, when I replaced the crank due to the balancer cracking there was no wear on the bebs or mains and the hone marks were still visible in the bores. Compression is only down slightly on factory, so I'm pretty confident in the motors ability to handle big boostI said go for it .. !!!!
and wonder how long your HD-T it's gonna hold ..
Haha with my pump it's just rolling coal until the turbo spools if you give it full welly off boost. 14:1 is not unheard of. About 12-1300 it picks up to 17:1 and the boost gauge will start to register, then 14-1500 it'll have about 5-8 psi. Yesterday I saw 35psi by 2000 rpm in 4th while towing, clearly it liked the extra load but the response was crazy quick, 8 psi at 1500 to 35 at 2000Rob could you please post up a vid of boost response of the BBX lower in the RPM range please?
I'm thinking from 1200 RPM in 4th gear on a flat road. Show the AFR if possible or just state how low it goes until boost picks up.
This can give some perspective on the suitability of each turbo for everyday driving. And give a good comparison for other turbos. This will enable manual and auto vehicles to compare with 1:1 ratio.
