speedometer cable
Discussion in '40- & 55-Series Tech' started by red66toy, Aug 11, 2003.
  1. red66toy
    red66toy GOLD Star
    1,509
    289
    Feb 25, 2003
    Seattle, WA
    I am going to be lubricating the speedometer cable in my FJ40 because the the needle was bouncing at speed and I was wondering what I should use to lubricate the cable. Thanks.
  2. roscoFJ73
    roscoFJ73
    13,079
    Media:
    3
    223
    Jul 22, 2003
    Perth Western Australia
    Just some axle grease will do it but I think you may find you need a new cable.You can get aftermarket ones for about half Toyotas price
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    I did this. Worked great. Remove instrument cluster. Disconnect speedo cable at both ends. Remove core. Clean housing by shooting spray carb cleaner through housing using supplied straw. Using needle type tip on grease gun pump two or three squeezes into housing. Clean core with rag and apply a thin coat of grease while reinstalling into housing pushing pumped grease through the entire housing. Remove all excess grease. Reconnect ends. Reinstall cluster. Load cooler. Go wheeling.
    ;) 8)
  4. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    mine on my 62 is boucing but all that for a bouncy needle? comeonnow :D
  5. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    Just giving you fair warning: Removing the speedo cable from the back of the instrument cluster can be a PITA.
  6. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    This memory dates back quite a few years but it may be worth a shot. Years ago I believe snap on carried a speedo cable luber. Basically a a set of adaptor gizmos that screw onto your grease gun on one end and into the speedo cable on the other. Squirt squirt and your done. Don't know if they are still around.
  7. Pete_S
    Pete_S
    74
    Feb 3, 2003
    I would take the time to purchase some spedo cable lube or use something like Sil-glide. Good ol' reglar grease might be too viscous for this application. IMHO
  8. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Did mine with grease and it works great but if you live in cold country I suppose it could get stiff.
