Someone stuck a diesel in my 80
Discussion in '80-Series Tech' started by Gumby, Aug 9, 2003.
  1. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    I have been hearing a loud rattle under my truck since a trip down to Attica in June. It sounds like someone stuck a Cummins in there.
    Apparantly somebody snuck into my driveway at night and bashed my catalytic converter with a rock. The media inside is broken up and rattling. Time to replace them with catco cats that will fit better with the sliders.
    The same vandal also bent the snot out of my exhuast. While it still passes gas OK and doesn't leak, it rattles. Might be time to find a better route that doesn't require so many passes under the frame.
    A big part of me says fix it with parts that work the way I want them to work. Another part says that Toyota's are the best made trucks out there and the exhaust has been no exception. 115K miles and it's in great shape other than damage caused by abuse.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Loose nut behind the wheel?............... ::)
  3. snowcruiser
    snowcruiser
    655
    2
    Jun 11, 2003
    Tell me more about these Catco Cats. Do they still use two large vertical cats or can it be reduced to one for the whole exhaust system. I want a one cat system so that the exhaust is less prone to overheating during long periods of idleing in the winter time. Any ideas???
  4. Atticus
    Atticus
    3,257
    124
    Apr 22, 2004
    Washington, D.C.
    I think I'm suffering from the same problem. What's the latest word on replacement cats?
  5. mac
    mac Crew Member
    1,059
    7
    Jan 8, 2005
    Wet Coast
    Time to ACTUALLY put a diesel in there...
  6. Trunk Monkey
    Trunk Monkey Moderator
    8,128
    416
    Apr 27, 2003
    Salt Lake City
    You can get a hi-flow straight through cat from Summitt for like $90. I put one on my 60, and the two OEMs on my 80 had been replaced with a single hi-flow by the PO.
  7. cruiser88
    cruiser88
    11,876
    Media:
    3
    31
    Feb 21, 2006
    Medford Oregon
    08-09-03, 09:51 Am
  8. Curran
    Curran SILVER Star
    824
    5
    Mar 27, 2003
    Frederick, MD
    That same scum sucking vandal hit my truck as well!
    I like the idea of replacing the two large rock magnets with one smaller, higher flow unit. How do you deal with the two O2 sensors with only one cat?
  9. p8nt
    p8nt
    796
    1
    Nov 30, 2006
    Traverse City, MI
    you can get a dummy o2 sensor, probably from summit as well.
  10. cruzizzle
    cruzizzle
    147
    Oct 20, 2005
    Akron,OH
    Summit does not sell them. Used to carry Caspers Electronics who had them, but Casper's ran across some issues with the emissions people.
  11. e9999
    e9999 You want to do what...? Moderator
    16,370
    387
    Sep 21, 2003
    PRK
    my recollection (hazy) is that in some states like the PRK, one must use OEM cats to pass smog certification...
  12. Atticus
    Atticus
    3,257
    124
    Apr 22, 2004
    Washington, D.C.
    I don't have inspection of any kind here in the Heart of Dixie, but I would like to make the rattle go away.
    My understanding is that a single cat will work, as long as it's a three-way catalytic converter. If properly set up, it shouldn't throw a CEL.
    True of false?
  13. duck
    duck
    56
    Dec 30, 2006
    :flipoff2::flipoff2::flipoff2::flipoff2::flipoff2: it was the good men at toyota
  14. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,120
    Media:
    180
    262
    Mar 31, 2006
    Central California
    Holy Thread revival!
    Is the rattle still there?
  15. Atticus
    Atticus
    3,257
    124
    Apr 22, 2004
    Washington, D.C.
    Mine is, since I posted today. As for Gumby's, I have no idea.
