Fzj80 1997
EDIT: The circuit boards for the TCM’s on both the original and the one I swapped in were messed up in different areas. My buddy with a 93 came over and we swapped his TCM in and it fixed my issues.
I bought a 93 FZJ80 equipped with a A442F transmission the other week. The truck had been giving the previous owner issues with the transmission and he had replaced all of the solenoids twice already with Izusu units. The previous owner also tried cleaning out the transmission connector near the starter. The connector broke and he repaired all of the wires by soldering and heat shrinking them back together. I saw this and immediately thought this was the issue, but after going through the wires and putting in new connectors, things are unchanged. When I received the truck, it would immediately die when putting it in drive. I swapped the transmission computer with another truck and that seemed to have fixed that issue, but the "stuck in overdrive" issue persists. swapped the ECU out with another 94 model and have driven the truck 100 miles. Check engine light has not come back on. According to the carfax, the owner prior to the guy I bought it from took the truck to midas to have its rear main seal replaced.
What the truck is doing:
When the gear selector is in "D", the transmission is stuck in overdrive. It drives fine, but obviously very low on power starting off. If you put the selector in "L" first gear is engaged and the truck can start off fine and you can move up to third by manually shifting through "L", "2", and "D" . On the highway stomping on the accelerator does not make the transmission downshift and when pressing the "overdrive off" button, the light illuminates, but nothing happens. The truck does NOT get a flashing OD light.
I had read a few threads on mud and a few people who have had the exact same issue resolved by cleaning out the transmission electrical connector near the starter, but as mentioned, I have had no such luck.
What I have done:
-Replaced the ECU with one out of a 94
-Replaced the transmission computer
-Rewired the connector for the transmission
-Replaced the neutral safety switch
-Made sure the fluid level is correct
It definitely seems the issue I am having is electrical related. I do not have an A442F transmission FSM. Any input is greatly appreciated.
What I have done:
