- Thread starter
- #2,061
Small update on my rear axle. Some of you know I had ordered a Rough Stuff axle housing, waited two months and never got it done. I since learned about Front Range and their Diamond axle, so I went with them and everything turned out good. If I had questions or problems, I called and talked to Brian the owner, very nice.
There can be a lot of small details that pop up that you just have to work through. We used 4runner brakes which I used up front, also. Thinking that would work with my wheels, oh no, I had to grind on the calipers and used a 1/4 spacer to keep them off the wheel. pulled everything apart and put in longer ARP wheel studs.
Then there's the parking brake cables. Not that easy to match up two 4runner cables to one 60 cable, a lot brackets and experimenting. Just about have it wrapped up and I'll move on to the exhaust leak at the header collectors. Need to get this done, CruiseMoab is coming up fast.
I'm very happy the way things turned out with this axle, a good company and I didn't feel bad spending money with them.
