Here is some information on the Landcruiser PTO winch which may be of use to others with similar OEM equipment. I have found the PTO gear case relatively maintenance free, but the downstream components typically need maintenance.
My PTO winch drive assembly for a 1989 BJ74 has 3 drive shafts, 2 pillow blocks and 4 U-joints and 3 slip joints and flanges at either end. It is about 6.5 feet in length.
Shear Pin
The shear pin is the first issue to deal with. The OEM shear pin and the so-called upgraded pin will break under a light load. If this happens during a recovery the large worm gear will hold cable tension. If the pin breaks during a self-recovery the vehicle will be immobilized. Once the vehicle is blocked the cable winch tension can only be released by removing the PTO driveshaft and removing the worm gear flange and manually turning the shaft to release cable tension.
The dog gear cannot be disengaged under tension. A worm gear is auto braking, which means only the PTO shaft can make the worm gear turn, but the worm gear cannot turn the shaft. So the shaft must be turned to release drum tension. The factory upgrade shear pin will break at a light load (1.5 tons), so it must be replaced. I replaced my shear pin with a two 6 mm cap screws and nuts it has been fine ever since.
Shear Pin
