Mike did your carb run at that angle? if it did I would be pumped, lotsa skinny to keep her poping is my experience
bustanutley said:Mike did your carb run at that angle? if it did I would be pumped, lotsa skinny to keep her poping is my experience
sebo4wd said:Fenders look awesome man.
What size lift and tires are you running?
Thanks,
Sebo4wd
The Cruiser or Mike??? and how exactly do you know it's saggy?bustanutley said:with a saggy ass
huh?treerootCO said:The biggest mistake I made was not watching the outside angle of the long bar. It wasn't the end of the world type stuff but it made it a little harder than it could have been.
If you start by leveling the vehicle front to back and left to right you can set everything at 0 or 90 degrees. The supports can be tacked and notched to the frame plates. Make them straight up and down, left to right, and level on top. Notch them so the fenders will be the same width. If you decide to make the bend around the battery tray, your passenger side fender will be way too wide unless you shorten it. Save the tube, you might need to extend the down part to compensate for the bend. Once that is all figured, add the plates to the bib and the lazer cut brackets to the firewall part. Once you get the stub piece notched and tacked to the firewall bracket, you can tack in the long piece. That is where I almost had it but missed one thing. As you slide the long tube in the notch of the support bracket and the firewall stub notch the top tube should be level. I made it level, made sure the skin would clear the front of the tub, made it 90 parellel with the rear of the tub, and tacked it in. I failed to check the rotation of the tube itself. Picture adding the skins on later. They are square so the outside of the tube needs to be straight as well. If you rotate the tube slightly in or out, the bend that makes the rear of the fenders changes. It need to be as straight as possible so that the skins will fit without being cut.
Clear as mud?
