Toyota’s lifetime is 200-250k miles. That’s not published, it’s just my viewpoint.If owning a Toyota now means replacing various parts early (to prevent failure) and doing 2-3 extra fluid changes before required, then I would get a Ford Raptor or Jeep Rubicon because those vehicles have aftermarket support galore (aka cheaper and more bountiful aftermarket parts; even dealer parts are cheaper). So those vehicles actually may end up costing LESS in maintenance / ownership when compared to Toyota LC with parts being more rare and more $$. So, LC has less features, less bells & whistles, and now more maintenance cost??
But yeah i see your points…just not what i signed up for.
Mini-Doug.
Your vehicle lifetime and my vehicle lifetime are different. If you buy an LC and are happy to get 250k out of it most trouble free then follow the maintenance schedule and move on. You will have some failures along the way because these are complicated vehicles and even with high MTBF on parts those failure rates add up, but overall it should be more reliable than comparable vehicles.
If you want to get 450-500k out of your truck (or more) then it’s going to require more maintenance than the book says. Maybe that is a full ATF exchange every 60k instead of “lifetime fluid”. If you don’t want to do the maintenance then expect to replace the transmission at 250-300k. Or sell it at that point and move on, nobody is forcing you to keep it.
My goal is 500k, just to say that I did it. More than likely when I get to 250-300k one of my kids will inherit it and I’ll build a used Gx550 or something else. So I’ll be aggressively over maintaining. But if I was thinking 200k and then trade in for something else I would not be nearly as aggressive.
FWIW I’m at 150k now and it drives better than the brand new 2024 4Runner Limited I drove while the steering rack was being replaced. Maybe I should have dumped the truck because I’ve done the radiator, steering rack, and valley plate, (oh and the gas tank spring went out, so that’s a 4th strike), but I see them more or less as wear items the way I use the truck. Well except for the gas tank spring, that’s just stupid
