Ignition switch light ring does not go off.
Discussion in '80-Series Tech' started by 94landcruiser, May 16, 2006.
  1. 94landcruiser
    94landcruiser
    1,064
    Mar 6, 2006
    Westwood, Ca/Ixtapa MX/Ahwatukee, Az
    I pulled my dash and replced all the bulbs in there (thanks Dan) and found the reason the key light ring did not light was the dead bulb.
    Cool I thought as I like everything to work. I replaced the bulb only to find the reason it was dead is because it never goes off. WHat turns it on/off?
    Thanks
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,055
    1,969
    Mar 27, 2003
    Which is the turn signal lever?
    The "Room lamp control" relay. 85965-60010, list $123.89.
  3. Koffer
    Koffer
    2,211
    3
    Jul 14, 2003
    Hopewell NJ 08525
    sounds like that bulb will be comming out real soon :eek:
  4. 94landcruiser
    94landcruiser
    1,064
    Mar 6, 2006
    Thanks Dan.
    I pulled it immediately no need for it to be on or to waste a bulb.
  5. LCphil
    LCphil
    106
    Mar 14, 2005
    Philippines
    Just a quick question. I have checked the FSM (I have all three volumes) and searched but cannot find the location of the room lamp relay - and I've looked.
    Thanks if you can help.
  6. toyman317
    toyman317
    1,671
    Aug 7, 2003
    Indianapolis
    Does this room lamp control relay also shut off the dome lights when the door is closed? Both my domes stay on with the door closed (switch in door position).
  7. 94landcruiser
    94landcruiser
    1,064
    Mar 6, 2006
    I have been looking for a year.
    Anyone know where it is?
  8. mudking82
    mudking82
    382
    Dec 9, 2007
    SoCal mountains
    On my 94 it is behind the drivers kick panel, behind the ABS module, bolted to the sheet metal.
  9. kirkagosto
    kirkagosto
    259
    Jul 17, 2007
    Mississippi
    ok my dome lamps work properly but the ring around the switch is not going off. Is it still the relay?
  10. Eicca
    Eicca Professional Noob
    1,817
    106
    Apr 26, 2009
    Utah
    There is no relay for the dome lights. Putting the switch in the "door" position makes it so the lights go to ground through a normally closed switch in the door jamb (that little black rubber button). When you open the door, the circuit closes. It's quite brilliant actually.
    Your circuit is grounding somewhere before those door switches. The trick will be to find out where.
  11. 80t0ylc
    80t0ylc Hill & Gully Rider SILVER Star
    2,285
    42
    Sep 24, 2008
    Canyon City, OR
    I disagree with your analysis, Taylor. On my '94, the "key ring" light only goes on with the driver's door open, stays on the whole time the door is open and fades to off about 5 seconds after door is closed. Also, the door ajar light is illuminated when any door, including the hatch, is open. OP did not mention that his door ajar light was on continously. He did mention that he just replaced "all the bulbs in there" and that he likes everything to work, so I'm assuming that his door ajar light is functional. If it was a short in the circuit, as you have concluded, the door ajar light would also be constantly on. So, I have to agree with cdan's advice.
  12. Eicca
    1,817
    106
    Apr 26, 2009
    Utah
    Ha! Wow I'm smart.
    There isn't a relay in the FJ80 so that's where I came from :eek: Thanks for pointing that out
