I need to get my little truck through smog in CA for the registration. It is a 81 pickup with a 22R engine, 4WD model, single cab.
The pre test showed that it fails with high hydrocarbons at idle. The cutoff is 200 something, and it read 600 something. At 2500 rpm everything passed fine.
I ordered new plugs (NKG G power), wires (NKG), O2 sensor (NKG), rotor (OEM), coil (OEM, the old one looks like s*** and has partially broken wires), dizzy cap.
When I brought the truck in it sat for an hour till they ran the test, so I suspect it was not hot.
The guy there claimed that the heat riser was slightly cracked, but I can't see a problem there.
What else can I do? Run it on on E85 for the test?
thanks, cheers,
jan
thanks, cheers,
jan
