Hazard light circuit wiring tip (1 Viewer)
Check p 37 took me a few minutes to figure it out, but should work!
Got it - so I need to pull out the stock flashers on the fuse box that come with the kit, install the jumpers, and that will bypass the Kwikwire flasher function and allow the original wiring to work as it should with an inline Toyota flasher. Thanks so much for the clarity - makes sense, and I don't have to pull the fuse box out to clip wires etc. 🙏
Did you get this to work as you described? I'm in that same boat right now.
Actually, no. I am stuck on some gremlins that have screwed up the lighting, so I'm seriously considering enlisting a professional. Pretty frustrating, but not the fault of anyone's advice here. I screwed up somewhere: I'm thinking it's a problem in the column wiring.
