If you measure at the pinion flange, it should be the same as measuring from the top of the knuckle, just add or subtract 90 degrees.
What do you mean my u-bolts look to be angled back to far? If they go though the plate under the springs, how could they be off?
I took apart the springs to grease between the leafs and install the new longer center bolts through the spring pack and shims. This was recomended by the local spring shop in Denver. I used c clamps to tighten down the springs, installed the new bolt with shim on top, top of the bolt sat in the perch just as it there was no shim.
You have shackle reversal so it would be fat side facing back. Fat side should face the shackles to correct for the longer shackles.
Alan, the shafts at the U joint touch due to the steeper angle. I don't know the terminology however where the "U" parts of the shaft connect with the U joint, they rub on the flange part when rotated. I know its the shaft and nothing in the axle or transfer case.
what about rotating the spring perches alittle. to point the pinion upwards?? are the springs on correct. and as far as the shim goes i thought i was right on mine but everyonee says i am not right
