Is this still a go? I am definitely interested in one!
Quick questions... I'm trying to decide on the color. How does the R50 and the Line-X tan go with the LC tan interior?
Is this the Line-x tan? https://static1.squarespace.com/sta...1/Outdoorx4+(14+of+20)-1-1.2.jpg?format=1000w
If so that looks great!
Thanks for putting this together!
I'd be in for R50 assuming it matches/compliments a tan interior. Simple flat surface, no grooves.
Of the three options, the LineX is the one that appeals to me most - the durability is a big deal to me. When camping, I use the tailgate a good bit to sit on, prepare food, etc so something that won't stain and is easy to keep clean is ideal to me. My interior is gray so black or dark gray are best for me, but depending on what most people want, I can be flexible.
Same as crimsonaudio...LineX, 1st color choice gray, 2nd black, flat surface with no grooves or cutouts.
Richlite is only slightly easier to clean because the LINE-X has texture. As I said, the Richlite is bomber. The only problem is that it can stain. Not easily, but some things will stain it. You can prevent most stains by keeping it waxed every once in a while, or you can even use finish on it. It's the exact same stuff high end cutting boards and pizza boards are made from, like Epicurean. I'd say go for Richlite if you are going to use the tailgate for food prep directly, otherwise the LINE-X will be a better color match- unless you already have a Trekboxx system, then the R50 will match the system's work surface.Yah, LineX for now, but if the Richlite is actually easier to clean and is tough, then I'm open to it as well. I don't know much about it, so I'll defer to those who do.
