ppc
M Go Blue
The speed sensor would only come into play during the lock cycle i.e. must be under 5 MPH. The unlock can occur at any speed.
Also, the front and rear locker harnesses are the same. Have you tried plugging in your front actuator into the rear locker harness connection? It should help narrow down any wiring harness problems if that works.
Curious to know if you ever found the definitive answer to your actuator problem? I recently took apart a gummed-up front actuator that wasn't working; cleaned it up and installed it with success--locker engaged almost immediately...and still does. Only problem is it will not unlock without manually doing the 'battery' treatment. Meter went kaput, so I have not checked continuity with 4/5/6 pins. Thanks.Great tips. I'll try later today and report back.
Any updates on this @SUMMIT CRUISERS ? My front lockers wont unlock after regearing/axle swap. Mine isn’t wired yet so it m doing the 9volt/12volt battery method. I can hear it lock and unlock but it does not really unlock since my steering was binding.
That cruiser has been parked since or you were able to somehow manually disengage the locker?Still no update. Definitely hasn’t been a priority. Other maintenance items on other vehicles have taken priority over the front locker.
