FJ40 front end swap
Discussion in '40- & 55-Series Tech' started by Rudical, Mar 16, 2003.
  1. Rudical
    Rudical
    1,439
    Mar 16, 2003
    Back to work
    I have a '71 FJ40. Of course with drum brakes. I have grease leaking in the front passanger side drum. I know the brakes have to br redone. I found a '76 FJ55 with disc brakes. It runs and almost everything works. The guy wants $600 for it. I am looking for information to see if the front end will fit with some ease. What else will I need?
  2. rusty40
    rusty40
    91
    Mar 6, 2002
    the axle will bolt up to the leafs ...
    the brake line (frame to axle)might come down to the axle on the wrong side
    the tie rod should hook up?
    and the drive shaft would probably need to be mixed matched 4spd + 3spd
    and your wheels will definatley go on
    If you have both cruisers it shouldnt be too hard
    oh yeah you might want to switch the brake booster for the disc brake one
  3. 73fj
    73fj Tho at sumbitch in ayer!
    1,058
    Media:
    36
    72
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    [/color
    if you had a 55 for 600 beans (thats 1500 canadian)lol is it in the driveway yet?
  4. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    piece of cake....
    swap pinion flanges so your driveshaft bolts up.
    yes, the brake hard line comes down the opposite side of the firewall
    remove the residual valve in the front system in the master cylinder
    tie rods identical
    drive. :D
