Noticed an exhaust leak and got under the LC and found this. I’ve had a rough idle as well and an intermittent CEL. Is the rubber boot necessary or can I just have a shop cut and weld new pipe in?
When you read the DTC which ones did you get?View attachment 3594821
By the time I got my hands on a code reader the CEL had went away.When you read the DTC which ones did you get?
I am betting that is made of mild steel and will probably rust out again in a few years. The OEM exhaust system is stainless (probably 409). I'd only replace it with 304 or 409 stainless pieces, otherwise you'll be stuck having to do the job again pretty quickly.Would this one be okay for my 1999?
A lot cheaper than the other options. I don’t believe it comes with the gaskets however.
