Hello all,
I have been very grateful for this forum and the resources it contains. I purchase a 94 LC several months ago and have been learning a lot since then. I recently replaced every hard brake line on the body/frame and all of the soft lines, as well as the LSPV. I thought I would share my bleeding experience with others in case any one else gets stuck. This procedure is for systems with ABS.
With all new lines, there is obviously a lot of air in the system. I had my wife help me with pumping the brake while I bled. I did it in the following order: LSPV, RR, LR, LSPV, FR, FL.
All seemed to be going except I could not get airless fluid out of the LSPV, and I could hear the "tink" of air/fluid in the lines. After hours (5-6) of bleeding, I decided to try something else. I used a air pump needle (like you would use to fill a football) and stuck it in the lid of the fluid reservoir (you have to take off the small cap on top and the little plastic piece inside the lid). I then used a regular air nozzle and regulator to put about 10PSI of pressure on the reservoir. Then my wife and I continued our bleeding procedure, starting with the LSPV. After about 10 pumps we got an enormous amount of air out of the line. I believe the long return line along the frame that goes to the ABS unit was harboring the air, and we could only siphon off a few bubbles at a time without the extra pressure. The total bleeding then only took about 7 minutes. I believe I was able to get all the air out of the ABS unit as well.
Hopefully this info can save someone a lot of time and frustration.
Cheers
Cheers
