88 FJ62 4.0 auto
The long story,
after an 800 mile road trip with some overheating, and trans mixing with T case gear oil also overheating, I made it home and began tinkering.
I drained the trans pan, and refilled with new ATF and some seafoam trans flush.
Drained the T case and temporarily refilled with ATF and some thick lucas trans treatment.
it was derivable and shifted smooth at this point
Changed the thermostat, this is where the engine started fighting back, did both gaskets and replaced the small hoses on the left side, and put in a bottle of prestone flush, ran ruff with high /low idle and flooding.
Cleaned the cold start injector, and new gasket.
New dis cap, rotor button and NGK plug wires, my plugs have less than 1k on them.
Did propane vac leak test and replaced the EGR gasket, and the cold start gasket again.
Removed the throttle body, it was gummed up, cleaned for hours with a toothbrush and acetone, installed with new gasket.
Changed every small vacuum hose.
At this point it ran but ruff, drove it a mile, and as i pulled back in it went to 2000k RPM idle when i shut it off.
it hasn't started scene., the starter turns, get a sputter, and nothing. I smell gas, so i unplug the wire that connects to the cold start injector, no change.
pulled the valve cover, new pcv valve and cover gasket, cleaned the cover for a day, and got the insides flowing.
Still no change.
The long story,
Still no change.
