Just purchased a 1994 HDJ81 with 188,000 KMs on the odometer.
So let the fun begin!
I will be maintaining a thread here and on ExPo. The technical stuff should stay here and the uplifting should go on ExPo, or at least that is the loose plan.
The current todo list looks like this:
- Engine oil [DONE, Shell Rotella Triple]
- Front Differential oil [DONE]
- Rear Differential (Limited Slip)
- Transfer Case Oil [DONE]
- Transmission Oil [DONE]
- ATF [DONE]
- Grease the driveshafts [DONE]
- Brake Fluid
- Coolant
- General lubrication of doors, steering wheel, hood latch, swing out, etc;
- Replace the headlights with NA appropriate models
- Figure out what to do with the mud flaps that are currently in pristine condition, before that changes. Thinking of trimming them and attaching soft rubber flaps;
- Fix the speedometer
- Move my OME coils and struts from my FZJ80 to this rig
- Caster correction bushings
- Check all the other bushings
- Fix the windshield washer fluid leak
- Fully test the batteries
- Check for anything loose, tighten it
- Replace the rear hatch window gasket and treat any underlying rust I find
- Replace the windshield gasket, treating any underlying rust
- Paint the roof and the piece under the wipers, maybe the hood
- Repaint the swing out
